spring loaded ball plunger
hello all,
I have a very basic question. I came across (on the web) a spring loaded ball plunger which is typically used on many indexing and tooling applns. I am curious to know if the ball at the end is capable of rotating if a horizontal force is apped (say friction which overcomes the spring compression).
Rephrasing the question, can the ball at the end be rotated at all?
Thanks in advance
Thanks in advance
RE: spring loaded ball plunger
Check the following site.
http:
MSU2000
