Anotations Fonts - Making changes "stick"
I've spent a lot of time and energy creating custom sheet formats and templates for my company. I started with an existing format that used Century Gothic as the standard font and I've tried over and over and over to change it to Arial (my company standard) but I can't get it to stick.
I've read in other posts that you make the change, save the sheet format and then save the file (to be deleted later) and I've tried that but it doesn't work. No matter how I do it, every single stinking time I open the slddrt (sheet format) file the anotations font is reset to century gothic.
Does someone have a fix? I can't find a damn thing in SW's help section about this issue.
RE: Anotations Fonts - Making changes "stick"
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
After making things the way you like them, do both:
File > Save Sheet Format,
AND
File > Save As > drawing template. This should fix the problem.
Flores
SW 2005 SP 4.0
Flores
SW 2005 SP 4.0
Shane Polwort
Senior Electromechanical Designer
Sierra Nevada Corporation
www.sncorp.com
Chris
FAQ559-1100
FAQ559-716
You will have to do this for each dwg size.
Chris
FAQ559-1100
FAQ559-716
Shane Polwort
Senior E/M Designer
www.sncorp.com
Solidworks 5
Chris
FAQ559-1100
FAQ559-716
Appreciate the help.
Shane Polwort
Senior E/M Designer
www.sncorp.com
Solidworks 2005
