contour variation during animation
Does anyone know how to allow the stresses to change with the part in animation mode in FEMAP post-processing?  This would help demonstrate where the peak values are (compression, tension, etc.).
RE: contour variation during animation
View, Options, Postprocessing, Contour/Criteria Levels, and then check the upper right, the animate box.
