Is there a reorder for Drafting sheets?
I have a drawing that, due to some changes in views, has sheets out of order in the tree...sheet 1,3,2, and 4.
I have not found a re-order function anywhere that will re-order these. I've tried to cut-and-paste the sheets; but, the section views that where created from other sheets loose the section callout in the originating view. I guess it looses some link. Is there a good way to re-order draw sheets in the tree and upper tabs?
RE: Is there a reorder for Drafting sheets?
One way is to copy/paste all views to the sheet you want them in.
/Akesson
