What does WAN means???
I would like to know what does "WAN" means (talking about SCADA system).
I will be very thanksful for any information.
Martin Torres
RE: What does WAN means???
Wide Area Network
More specifically you can view your networks in a couple of different ways LAN and WAN are the most common. Your Local Area Network would most likely be contained with in a plant or factory. The WAN would be the network that connects several plants or factories together.
