Hollow Core Planks
Hollow Core Planks
I was asked take a look at some spalling of elevated concrete and corrosion of steel framing at an oil change location. What I found out is that it is precast planks and there are numerous locations where the prestress strands are exposed and rusted. 95% of this is near the bearing end of the plank section. The pit openings have a steel frame around them, all of which are heavily corroded and appear to be causing deterioration of the adjacent concrete.
I have been asked what my recommendation is. My first thought is to remove the exist. concrete planks & steel and replace with new. I know approach work is neccessary because I beleive there is water penetration near one of the bearing locations causing some of this excess moisture problems.
I am just looking for any alternate solutions and opinions, I think it is better to look for a long term fix than a quick band-aid solution.
RE: Hollow Core Planks
Would you suggest using removable forms or possible a metal deck form that could be left in place? Would you analyze as a composite section (new 3" and exist. hollow core) or design the underslab as a one-way slab to for the required loading? With the exist. planks bearing on the walls, would you use an expansion joint at the underslab/wall joint?
With water as a potential future problem as well, I'm hesitent to use metal deck - rather use temporary forms.
I believe that the concept involves using the plank and the underslab together as a composite unit.
I would try to develop added support so that the new underslab is also adequately supported at the ends.
