Looking for a source of extreme temp refractory
Hello.
I am looking for a supplier of magnesium oxide, aka, magnesia tar.
There are a couple of forms it comes in, but it is basically the same chemical, and about the only thing available, outside black projects, that will routinely take 5 to 6000 degrees F.
Thanks.
RE: Looking for a source of extreme temp refractory
What did you not like about your websearch hits?
TTFN
Try this:
Heat Industry Products
4143 West Post Rd.
Chandler AZ 85226
jenright"fifty"ATcoxDOTnet
(replace caps with symbols and quotes with #)
"What did you not like about your websearch hits?"
Sort of like being new in town and opening up the yellow pages to the restaurants.
Tons of them, but you wonder which ones are good, so you ask a local.
Thanks Nick.
Isn't that the same stuff as Phillips Milk of Magnesia? We used to use it as a stop-off paint for hydrogen atmosphere nickel brazing.
