Pump Stations
Pump Stations
I am starting to size pump stations for developments I am working on. I am wondering if anyone has or knows of a free program that can give me a rough pump sizing.
I would need to see the relevant curves but nothing to stick my life to just something for a quick calculations. I am in Australia so it would need to be metric.
Any help would be appreciated.
R.J.L.
Civil Designer
www.qmcw.com.au
RE: Pump Stations
An Excel spreadsheet can quickly convert flow rates and pipe sizes to head loss via the Hazen-Williams (or even Manning's) equation, which can be found (even quicker) with a Google search.
Be careful determining your controling point if you have multiple local high points beyond the high point on the forcemain. You need to ensure that (static head available) is greater than (dynamic headloss) between the highest point and subsequent local high points.
Josh Madison's conversion program here will get you around metric <--> imperial unit conversions.
RE: Pump Stations
Goulds pump software is on the Internet so you dont even have to download it or wait for a CD.
All are represnted in Australia.
If you need waterhammer analysis done to comply with WSAA standards get in touch. I am Sydney based. I also do extended period simulation and network analysis.
