Functions at the prompt
Hi...
I am writing a code for Newton-Raphson Method. I wrote three M-Files:
1)Function m-file
function f = f(x)
f =  input('Enter Your Function Interms of x   ');
2)Derevitive m-file
function df = df(x)
df = input('Enter The Derivitive Of The Above Function Interms of x   ');
3)Script m-file (was done with help of online resources)
a = input('Enter Your Initial Guess   ');
Tolerance = input('Enter The Desired Tolerance   ');
error = 1;
n = 0;
while error > tol
   x = a - f(a)/df(a);
   error = abs(x-a);
   n = n+1;
   if n > 25
      error('Excessive iteration and no convergence.');
   end
   a = x;
end
disp('Tolerance (s)')
disp(Tolerance)
disp('Number of iterations')
disp(n)
disp('Root of function')
disp(x)
The Script File works just fine, especially the part of having the user to enter his/her values. But as you can see for other M-Files, I want also the user to enter his/her function as well. But the method is simply not working.
I want a way in which the user can input the functions manually. Is there such a way?
Thank you guys.
