Calculation work
Calculation work
Hi Folks
When working in SolidWorks does anyone run into the need to do complex math such as Stress,Fluid Flow,or other Engineering calculations?
Do the results of those equations result in changes to the solid model?
If so how do you do it now?
Is it easy to tie in an Excel Spreadsheet for example?
Does SolidWorks have a Math Modeling tool available that is linked directly?
Lastly is there a 1D/2D/3D tollerance package available that is linked to Solidworks?
RE: Calculation work
no
manually change model
yes
not that I know of
no
Have you had SW/Cosmos training? Have you used the tutorials or help?
Which version are you using?
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Regarding your question about tolerance analysis packages, here's one that might be worth checking out:
http://www.varatech.com/sigmundworks.html
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Just because I'm paranoid doesn't mean that they aren't out to get me.
- Woody Allen
Chris
FAQ559-1100
FAQ559-716
check out link for brief synopsis:
http://www.cad-portal.com/news/index.php?id=9
Thanks, I didn't know they added it.
Chris
FAQ559-1100
FAQ559-716
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
