Display parameters to Rotate with Model
Is there an option that I can put on so the Flagnotes, GD&T Callouts, Dimension, etc will rotate with the model?
RE: Display parameters to Rotate with Model
Open the model, chose application drafting and dont select any sheet Or even if you have selected, switch back to model using "display sheet" from "format " pulldown menu.
Here u can add dimension and Flagnotes,etc...
and you can also rotate the model.
