ASTM A105, European spec
Can someone help me find an equivelent spec. to the US ASTM A105 or A 105M carbon steel.
Thanx in advance,
               Gary (UK)
RE: ASTM A105, European spec
BS 1503-161B, DIN C22.8
It depends what you want it for?
An A105 is a carbon steel forging, its nothing fancy.  Do you need a forging?
A105 is quite common for flanges, even in the UK.
If it's a special flange you are making, roll a piece of boiler plate into a ring, BS1501-161-430A  or P265 etc.
Depends on your client requirements and contract spec etc.
www.gowelding.com
Thank you all!!
Problem solved
Can anyone tell me what NACE stands for?
Devan
I think it is Natioal Association of Corrosion Engineers
