Plunger locks
Plunger locks
We are installing a tech work station in a small twin a/c.
The work station has a swing out LCD display that obstructs egress down the aisle. Current two pip pin scheme requires too many motions in an emergency. What we are looking for is plunger type locking scheme that can easily be overpowered to swing the display out of the way. Ideas??
RE: Plunger locks
ht
http:
RE: Plunger locks
Thanks for your rply and suggestions...we will investigate.
The bits do not have to be TSO/PMA since I'm a DER and the a/c will be Experimental for these studies. Thanks, John C.
