K-factors for wire mesh screen
I'm trying to find data on the pressure loss coefficient for flow thru wire mesh or perf plate.  Everything I have shows the basic K-factors for square edged inlet/outlet, contraction/expansion sections, etc.  Nothing on wire mesh or perf.  Any suggestions on where to find this information?
RE: K-factors for wire mesh screen
Try Koch-Glitsch.
My Perry's Chemical Engineers' Handbook (6th Ed.) has a correlation starting on page 5-46.
Good luck,
Latexman
Idelchek Fluid Reistance a Design Guide for Engineers
There is an old publication called 'Low Head Power Plants' by Mosonyi (a fairly thick A5 book).
A formula has been included for trash racks & mesh screens called (I think) Kirshmers formula.
I have used it to calculate head losses for mesh screens (around outlets from reservoirs) & trash racks (in front of intake towers for dam structures), for water utility applications.  You will find that the head loss thru screems & trash racks is fairly low for approach velocites of 1 to 2 m/s.
BarryEng
I found the publication.  It is called Water Power Development by Emil Mosonyi, Volume 1 is Low Head Power Plants, 1963.
The formula is on p251 in Chapter 23.
Kirschmer's formula
head loss = (phi(s/b)^^4/3) (v^^2/2g) (sin (alpha))
Where phi = 2.42 for a rectangular bar
          = 1.79 for a wire
      s = width of rack bars
      b = spacing (clearance) between bars
      v = velocity of approach (not thru opening)
      alpha = angle of bars with the horizontal (trash rack tilted back 30 deg off vertical, alpha is 60 deg)
Perforated plate head loss would just be a sum of head losses thru all of the orifices.
BarryEng
