hydraulic cylinder ends
Does the lug on a hydraulic cylinder or fork in the mating part usually have a bush, or does the pin locate straight to the metal (in cases where the movement might only be infrequent, say once per day)
What do the rams that are used on JCB type machines have?
RE: hydraulic cylinder ends
I think the bushing is a good idea as I have a friend that has made a small fortune weld repairing and machining connections on hydraulic equipment.
Here are two people that supply the bushings that you might want to look at.
http://www.connexusa.com/
http://w
