Active Noise Control (ANC) for construction equipment?
Hello Everyone!
As some of you might know, in 2006, according to noise norm for 2006 for construction equipment, the noise produced has to be strongly reduced (at least here in Europe, I don't know in the US).
We are trying to reduce the noise levels of our machines (excavators, notor graders and wheel loaders) by using standard passive noise cancelation. Roughly seen, we are covering everything with foam! I've been reading about Active Noise Cancelation and how good it can be.
I've found in the Internet, just prototipes for Active Noise Control for mufflers, air intakes and for radiators (for fans) but no commercial units.
Could someone point me to copmanies who build this kind of equipment commercially?
Thank you for your help.
Claudiodeviaje
Claudiodeviaje
RE: Active Noise Control (ANC) for construction equipment?
I don't think you'll have much luck to be honest. A conventional passive system will probably be more effective.
Cheers
Greg Locock
I get the impression that you're trying to reduce drive-by noise, which would require some sort of phased negative acoustic radiator for each noise source on the vehicle.
It would have a chance of working on the exhaust pipe, except for heat and corrosion issues, but passive technology exists for dealing with that already; it just takes up a lot of volume. Figure on a muffler with roughly the same gross volume as the engine itself. {Overall envelope volume, not cylinder displacement)
Actively offsetting the noise emission from cooling fans, gearboxes, and valve clatter, for external observers from arbitrary directions, is ... I don't want to say impossible, but I'll say challenging in extremis.
Look at alternating layers of foam and mass- loaded plastic, applied to the radiating surfaces.
Mike Halloran
Pembroke Pines, FL, USA
Digisonix designed and built some commercial systems for use in HVAC ducts and stacks. Pretty impressive. "turn off the noise" or maybe "turn on the silence."
Now they are part of someone else and are reportedly working on engine (exhaust/intake ?) noise.
http://www.signalsystemscorp.com/anc_news.htm
Due to cancellation error, it is limited to rather low frequencies, and due mostly to processor (and algorithm) limitations, it is also limited to machinery that does not change speed very quickly.
I have seen active noise technology applied very effectively, however, to intake noise on constant speed equipment such as blower-type bulk transfer machines, and to industrial vacuums - floor sweepers.
Regarding piezo-electric "patches" for active vibration control: "Vibration-X" is in that business, in Winchester, Mass. They have both active and passive piezo-devices for vibration control.
But I think you need to go back to basics and understand all your noise sources, and treat them individually, rather than just trying to put a big foam "band-aid" over the whole machine.
