Brick wall damage
Brick wall damage
Further to my threads on the high CO content and capacity of the ID fan , and following the difficulty of the ID to induce a negative pressure on my boiler at full load, we are now having side wall damage. I presume the damage is caused by the constant puffing inside the combustion chamber due to the boiler running at positive pressure.
I wish to ascertain if the real cause is the incapacity of the ID to maintain negative draft inside the combustion chamber.
Thanks for any input.
Bob
Bob
