SAP2000
SAP2000
Can some1 out there help me out?  I'm using SAP2000 to do structural analysis.  How do I go about (the steps) to show the internal member force? For exe: for member AB, Fab = to some force.
Thanks a bunch ahead of time.
RE: SAP2000
The best way i have found is to go to File...export to excel...there you can chose to export input and output data...choose no input and some output....then you can check frame forces ..clicl ok a couple times and excel starts up with the info you are looking for.
you can also go to display...frame forces then choose axial moment or shear
good luck
