Bristol remote set regulators
Does anyone know the reason why a RSR would bleed gas continuously. I'm looking for a fix to a problem at a reg. station that is a remotely controlled station. There seems to be somewhat of a constant bleed. Would rebuilding the "block" on the RSR solve the problem?
RE: Bristol remote set regulators
Becker makes non-bleed controls. Actually, they bleed, but the gas is exhausted into the outlet line.
There are other non-bleed (or minimal bleed) regulators available, depending on what pressure you are working with.
