how to adust the expansion of glass and polyester resin
I am presently sticking glass( of 4 mm thickness ) using polyester resin onto fibre glass of around 2mm thickness . However the problem I have is that many of the pieces seem to break after some days .
My feeling is that there is an incompatibility in the coeffecient of expansions of the two materials namely glass and resin leading to this cracking during shipment by air .
I would like to know if someone has had a similar experience and the possible solution for this problem .
Thanks in advance
Thanks in advance
RE: how to adust the expansion of glass and polyester resin
