Need to bond PP to card (Adhesive needed)
Hello.
I was hoping if you could help me with a problem.
I can't seem to find an appropriate glue (preferably Hot
Melt type) to bond Polypropylene and card. This needs to
be a long term bond as the part needs to be intact for a long time after production
Is this possible or would anybody be able to recommend a
suitable glue so that I can make the necessary purchase?
I've been stuck on this for ages, none of the Hot Melts
I've used have worked.
Thank you very much.
RE: Need to bond PP to card (Adhesive needed)
