Air Handler to Plenum
Can anyone help in recommending the best way to adapt a Goodman ARUF30 air handler to existing duct work from an oil fired furnace? The Return Side hood is 20"x20" on the furnace but only 10"x20" at the joist level. The heat side is 21"x20" on the furnace with the same at the joist level.
Goodman air handlers need to feed from the bottom - up, so there has to be some kind of support base to hook up the return plenum.
Again, any suggestions would be appreciated...
JR
JR
