Starpoint Earth
Starpoint Earth
Please indulge Mainly mech engineer.
Am I right in thinking starpoint earth on a genset is all componants connected to one point as opposed to connected in series ie to each other first (floating)
RE: Starpoint Earth
The Wye or Star configuration of windings in a 3 phase generator or transformer means that the ends of the 3 phases are all connected at the star point. Voltage L-L=Voltage L-N(1.732) Always. For example 208 = 120(1.732)
Connections other than the star connection point may be series or parallel depending on the configuration of the windings and the voltages desired.
RE: Starpoint Earth
(IEEE Recommended Practice for Grounding of Industrial and Commercial Power Systems.)
You can download it at:
http://s
Failure seldom stops us, it is the fear for failure that stops us - Jack Lemmon
Make the best use of Eng-Tips.com
Read the Site Policies at FAQ731-376
