Viewport Locked Up
Viewport Locked Up
I am running CAD 2000. I have a viewport into model space on my drawing. For some reason I can't get to the properties command for the viewport. I can'y unlock the viewport to change the scale or to adjust the area being viewed. Help!
RE: Viewport Locked Up
The long way at the command line: mview > l (for lock) > off > pick vport.
Flores
In AutoCAD R2000.
In paper space.
Can you right- or left- click the viewport border?
If so, can your right-click and scroll down to select properties?
Or, can you left-click it to select it and then look on the layer pulldown on the top of the screen to see what layer it is on?
just my 2 cents worth...
Flores
