SIGNIFICANCE OF OCTAVE -ANAYSIS
How the nature of deflection of rollers in rolling mills is figured, knowing the octave band(i.e, 3rd, 5th etc.) and vice-versa.
RE: SIGNIFICANCE OF OCTAVE -ANAYSIS
C. Hugh (www.Hatch.ca)
this is concerned with the roll shape deflections occuring due to roll chatter.To elucidate further, the text matter reads as follows:
The fig.(referring to modal deformation of mill with strip) seems to correspond to fifth-octave-mode of chatter on sheet mills.
After going through this text material* i got the above question.
*Flat processing of steels ------- William Roberts (pg. 597)
