needle bearing calculation
What are some of the factors that determines the strength/load of a needle bearing?
Factors such as number of rollers, diameter of rollers, diameter of inner race and outer race.
Does the strength increase with the number of rollers? or the diameter of the rollers? or both.
RE: needle bearing calculation
elements, the bearing mean diameter, the depth
of case, the hardness of the raceways,
the length of the rollers and by the square of the
roller or ball diameter.
