"Measure" just stopped working
I'm trying to measure the distance between two things in an assy, (2005 SP 5)
I'm doing what I normally do, but all of a sudden, if I click on entities, nothing shows up in the "measure" window. If I then click on the measure window, it will give me info on the last thing I highlighted. But it won't let be measure the distnace between things.
Did I accidentally turn something off?
RE: "Measure" just stopped working
That's strange.
Not quite a solution for that problem, but may help meanwhile:
Use the dimension tool in the sketcher to measure between a face and an edge (or two parallel faces or angled faces, etc.).
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Try shutting SW down rebooting hte computer and see if hte Measure still doesn't work. If it doesn't then do a Repair on your SW.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
One of my users ran into the problem recently.  Restarting did the trick.  He had quite a few parts and assemblies open, and I think it caused a memory leak.
Measure worked again after the restart.
TJ McDermott
Formost Packaging Machines
Yup it worked. It happened again though...so I shut it down for the week.  Pretty annoying little problem I must say...
I have seen the same thing happen at my workplace.  What fixed it was a repair on the install, as Scott suggested.
What is this "repair" of which you speak? I just did a search in SWx help, and nothing came up.
How do I Repair or Modify of a SW Installation?  FAQ559-908
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions  FAQ559-1091
