TSA AISI316L against 22 Cr duplex
Hello everybody. Is there anybody who has any knowledge about the use of thermally sprayed alluminium coated AISI316L against bare 22 Cr duplex steel within an environment containing hydrocarbon and water?
thanks a lot
Max
thanks a lot
Max
RE: TSA AISI316L against 22 Cr duplex
Steve Jones
http://www.pdo.co.om/pdo/
My doubts regard the inherent porosity of thermal spray coatings and therefore the contact between substrate material and aggressive environment.
http://w
Steve Jones
