600V Generator for 480V System
If I have an existing 600 volt, 3 phase, 60 Hz generator, approx 1500 kva, can I use it on a 480 volt system. The field current must be lower and the rating reduced to 1200 kva. Is this possible?
RE: 600V Generator for 480V System
The generator can be loaded up to its capability curve, but this must be re-drawn for the lower terminal voltage. Why not check the manufacturer for specific recommendations?
dydt
