leader line convention
Being an electrical engineer with limited knowlede of drafting conventions, I need help resolving the correct method of indicating radius location for a metal panel.
I have a 2" x 5" metal panel. The panel has a 1.9" x 4.9"
milled out area with a 1/4" radius corners on the milled out area.
Is it ok to have an external leader line pointing to the milled out radius or does the leader line have to begin internally, as to not confuse the machinist into radiusing the 4 outer corners of the part as well?
Is either convention acceptable?
RE: leader line convention
I would probablly put 1 leader off of one of the 4 radius corners, leaving the dim inside the sketch of the part.
marking as 4X R.25...
But hey, thats just me.
Wes C.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
4X R.25
The only time a dimension should be on or inside a part is when you don't have any other option.
