Plate style heat exchanger for a MHF
I have a problem
For one of my projects I have a municipal Multiple Hearth Furnace that we are trying to rob some heat for process water. The top of the incinerator is a huge metal plate and it is about 300 F. I need to find a flat heat exchanger that will transfer water from the furnace to the water(not the air as many of the ones I have found do) does anyone have a suggestion on who makes these types of heat exchangers.
Thank you
Thank you
RE: Plate style heat exchanger for a MHF
rmw
Dan
