SolidWorks archetectural
For you guys that moved from AutoCAD to SolidWorks, has anyone used AutoCAD for architecural or building/office layout and moved that data for use into SolidWorks? Or is there a program that you use for doing this type of work in SolidWorks? I am trying to find a way to do office layout in SolidWorks and also translate that data to architects using AutoCAD. We are doing a layout of the building. I do not want to use DXF or DWGEditor. I want full control withing SolidWorks if possible.
thanks
thanks
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
RE: SolidWorks archetectural
Sounds easy enough. You will need to model your floor plan in SW and create the drawings in SW. Then save the SW drawing file as a DWG so your architect can open the file with AutoCAD. I have done some basic architectural work in SW. 3D is so nice for seeing space relationships. I have used SW many times to model a building and then translate the exterior elevations back to AutoCAD. It works well. SW does not work well for adding all the details required in production architectural drawings though. I would still do this work in AutoCAD.
Rob Rodriguez CSWP
www.robrodriguez.com
SW 2005 SP4.0/SW 2006 EV
Do they NEED, the hard data, or are they going to take your layouts, and input them into thier software anyway? If that is they case, why not just give them an e-drawing.
Wes C.
Last year I gutted my kitchen for a total remodel. I did the cabinet design, and lighting in SWx. It was mainly for my own gratification and visualization. Although, it did help us when we manufactured the cabinets. I submitted a 2D layout to the contractor who was trenching my foundation for the island.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
In AutoCAD there are blocks with all the symbols needed for office layout and LISP programs for automating the task which also creates BOM's, cost, etc.
I want to send the dwg files back with the symbols, but not have it affect the compatibility with their symbol library.
They do not want edrawings, it is too far into the future for them. :)
Rob, thanks. I'm going to import what I have from ACAD to SW, change it, then send back and see what happens.
...wish it were ALL SW!
Chris
FAQ559-1100
FAQ559-716
Rob Rodriguez CSWP
Chris
FAQ559-1100
FAQ559-716
