Bolt marking
Bolt marking
Bolt marking
I have some SA-193 B7 bolts, some are marked B7 and some are marked J B7.  Is there some significance to the "J" marking?
RE: Bolt marking
J most likely means it is a rolled thread, vs. a cut thread.
Wes C.
RE: Bolt marking
Isn't the J a rounded end to the thread?
RE: Bolt marking
ajack is right, it means the
thread a full radius, and needs the
mating part to be slightly truncated
as to not interfere with the radius.
RE: Bolt marking
thanks for setting me straight guys.
Wes C.
