Finite ELement or Classical Rankine Analysis
I have the latest RAM Advanse 3-D F.E.A. for a Retaining Wall Design. When I compare the results with the typical way of designing a retaining wall with my F.E.A. the results are very different. I am wondering if anyone has found this to be a very conservative approach or is it more realistic. An article by T.C. Goh in 1993 shown in the Braja Das book confirms a much higher lateral pressure value than the classical Rankine Ka active pressure behind a wall fixed at the base to a large footing.
RE: Finite ELement or Classical Rankine Analysis
Good luck.
Thanks for the response. I have the Goh analysis research paper done with finite element analysis in 1993. He basically says from the top 1/2 or 1/3rd down the wall you should use 1/2 the way between Ka and Ko say 0.4. He does not heavily compact the bacfill for his 12 foot high wall. His results look pretty accurrate as does mine with RAM 7.0. The real trick is which method do you use. Either Rankine, Coulomb, EFP or At-Rest and how the failure wedges develop directly behind the wall. I like for years the IES Quick R Wall software program that uses simple statics like AASHTO and CRSI and does a real professional looking job.
If you want to use the failure wedge theory and your wall is long, you'll have less steel and be able to produce economical design. As for compacting the bakfill, I would not be concerned with a 4 foot roller that has the vibratory turned off and 9" lifts of granular backfill. To learn more click on
http://w
Appreciate the nice link. Personally I think the EFP method is the "quick & dirty" too easily understood way to analyse a retaining wall. I lean towards the Coulombs method since most of my footing heels are not that long and the wall friction clearly helps the stem design to be economical as you indicate. All that said, I do check all the different methods anyway and make a choice comparing all the results to the CRSI Tables. The F.E.A. method highlights the complex stiffness, rotation, deflection and translations a retaining wall actually goes through.
Your absolutely right about quality soil data. Every retaining wall job I have ever done working for an Architect or an owner,I get no soils info/report at all much less a soil modulus. I just indicate the required soil/rock conditions I used for the design. I think that Goh and Casagrande had it right when they say, the typical "safety factors" used for overturning, sliding, shear and stem moments are enough to keep the wall from actually failing as the pressures developed behind the wall clearly exceed the classical Ka values.
