long term strength in clay
I have heard a lot of opinions on the residual strenght of clay in slope stability problems. Some say only to used the friction angle of the clay for over the long tern because the cohesion element becomes 0
I have tri axial CU tests showing 10 deg friction and 1000 psf cohesion. I wanted some others coments on wheather you think neglecting the cohesion is overly conservative. If I neglect the cohesion the slope will have to be constructed out of other material or heavely reinforced. If I use cohesion the slope is perfectly stable.
RE: long term strength in clay
