Creating New Drawing SW2003
I have Solid Works 2003 running on win XPpro
When I try to create a new drawing I click new and the new SW document dialog box pops up but the icon for a drawing is not there under the templates or tutorial tabs.
Does someone know where it is or what I might be doing wrong?
RE: Creating New Drawing SW2003
I think that is the default location.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Wes C.
The standard tutorial templates can be found at C:/Program Files/SolidWorks/lang/english/Tutorial
The Tools > Options > File Locations lists all the standard file paths, but if you have customized any templates, (or intend to) you should save them in a separate folder (which should not be in the SW install directory) and use the File Locations dialogue box, to direct SW to them. If you don't they will get overwritten when you re-install a new version of SW.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
