Ethanol Plant Hazardous Area
I need a links about - Ethanol Plant Hazardous Area Classification.
I have to start work on Instrumentation and Controls as Electrical Engineer, but Hazardous Area Classification is also coming on my desk one day.
Thanks.
RE: Ethanol Plant Hazardous Area
  You really should started with the foundation, which would be the NEC (National Electrical Code).  The NEC defines the various hazard classes and their application.  I'm not sure if you posted in an Electrical Engineering forum, but that would be a place to ask the same question.  The audience there will be much more informed on the specifics of the NEC and its application.
Best Regards,
TSeener
