Unit conversion
Unit conversion
How to change the units only. I mean to say, I have modeled a component in Inches and I want it now in millimeters. I just want to change the unit from Inch to mm, keeping the values same.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Unit conversion
Also... thread559-134247
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
RE: Unit conversion
This will NOT reduce the model size. It will just convert the dimensions from Imperial to Metric. If you need to change the model from say 6 inches to 6 mm, you will have to adjust each dimension manually ... unless someone here knows of a macro????
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
RE: Unit conversion
That may help you.
