Autoinsert Rows
Autoinsert Rows
Autoinsert Rows
I have a large chunk of some production data - some 4000 lines and have it sorted by date. Is there a way to automatically segment the data so that I can put in a line or two under each date or to separate the data day-by-day so that I can minipulate certaion portions of the data?
RE: Autoinsert Rows
How would a couple blank lines in a 4000-line file help you any? You could write a macro takes each date's data and put it onto a separate sheet. Surely that would be more useful than blank lines?
How do you want to manipulate the data? Would a simple filter do the trick for you?
RE: Autoinsert Rows
Perhaps I've missed something here, but this is very easy to do in a VB Macro. If each row contains data for an individual date, the following code will insert 2 rows under each date ...
Sub insert_rows()
' Last row with data in it
last_data_row = 4000
' Number of rows to insert
numrows=2
For i = last_data_row To 1 Step -1
    Rows(i & ":" & (i + (numrows-1))).Select
    Selection.Insert Shift:=xlDown
Next i
End Sub
RE: Autoinsert Rows
This will do what you want provided, as you mention, the spreadsheet is sorted on column A.
This routine does the following:
1. Determine the last row used.
2. Working from the last row used upwards it compares
   the value of column A in the current row to column A in
   the row above.
   if they are the same nothing happens.
   If they differ then 2 rows are inserted.
Dim i As Long, LastRow As Long
Application.ScreenUpdating = False
'finds last used row in column A
LastRow = Range("A65536").End(xlUp).Row
For i = LastRow To 1 Step -1
  If i >= 2 Then
    If Cells(i, "A") <> Cells(i - 1, "A") Then
      Rows(i).Insert   'add 1 blank row
      Rows(i).Insert   'add another blank row
    End If
  Else
    End
  End If
Next i
Application.ScreenUpdating = True
RE: Autoinsert Rows
I use the ASAP "smart difference" function to insert formatting, blank lines or page breaks just as you desire.  I am not sure if it is allowed to mention specific companies, so feel free to red flag this if it is not appropriate.
