dc power boost
dc power boost
I have a dc source of about 1 volt and I am looking for a circuit to boost the voltage to 2 volts at 20 ma
RE: dc power boost
RE: dc power boost
These are just some thoughts, I hope they help
RE: dc power boost
I'm not sure how low these circuits can go (PS voltage) but I think that some might be able to run as low as slightly less than 1 volt.
Where does the 1 volt come from? It's an odd voltage.
RE: dc power boost
http:
TTFN
RE: dc power boost
much lower input V, using synchronous vibrator ...
<nbucska@pcperipherals DOT com> subj: eng-tips
read FAQ240-1032
RE: dc power boost
RE: dc power boost
electromech. vibrator chops lowV for xformer. extra two
-- SPDT-- contacts ground one end of secondary. The centertap is the DC output.
I suggest a better solution:
Use 3-4V rechargable battery to drive oscillator-FET swith.
FET chopps low V; start from battery, recharge it from AC output.
read FAQ240-1032
RE: dc power boost
The thermocouple was a pilot flame detector salvaged from an old gas hot water heater. The thermocouple generated around 10mV at 50mA (from memory) when attached to a soldering iron tip !
I did get my six volts, but even my multimeter loaded the output significantly. Flea power indeed, only half a milliwatt input power, but it was an interesting thing to try.
It is what happens during retirement, too much spare time.
RE: dc power boost
Sweet.
Thanks for that info nbucska!
Warpspeed.. external powered... uh huh.. with that sneaky balancing resistor in there between the external power and the thermopile??
Yeah I bet it had horrible load regulation. Flea complain?
RE: dc power boost
Westinghouse made the power supplies I saw. It was the same division that built sonars and polaris submarine systems. I don't think it exist anymore.
RE: dc power boost
RE: dc power boost
TTFN
RE: dc power boost
RE: dc power boost
As you might imagine, since TOW dates back to Vietnam and any other form of energy storage would bleed down over any normal military storage, a more permanent energy source was needed. The thermal batteries, once the chemical stability is dealt with, can be stored for long periods, and then removed and immediately used.
TTFN
