Dilution of H2SO4 with water and HCl: ternary system
Hi
I am diluting sulphuric acid with water and HCl. I do not have the choice to dilute it with water only. The specifications are here below:
Stream 1:
98% H2SO4
2% H2O
Stream 2:
19% HCl
78% H2O
3% CaCl2
Stream 3:
55% H2SO4
35% H2O
8% HCl
2% CaCl2
Where can I find the equilibrium/thermodynamic data on this ternary system? I couldn't find any information concerning this problem. Are there any papers published on this mixture? Will HCl flash off due to large heat generation or not? How does the presence of HCl affect the amount of heat released from the dilution?
Thank you
Atlas99
Stream 1:
98% H2SO4
2% H2O
Stream 2:
19% HCl
78% H2O
3% CaCl2
Stream 3:
55% H2SO4
35% H2O
8% HCl
2% CaCl2
Thank you
Atlas99
RE: Dilution of H2SO4 with water and HCl: ternary system
The heat release seems to be much less. I think that it is best to carry a lab experiment. A full enthalpic/electrolyte model may help you (simulators like ASPEN can do that)
