How do you change the line type used in a shortened section view?
When I take short section views of a long part, Catia will cut the part with a phantom line. We need to use a break line. Is there a way to change the line type catia uses as a break line for a shortened section cut/view?
RE: How do you change the line type used in a shortened section view?
change your standard XML file, read online doc about standard file and setting up environment.
