What Type of plastic to use
I have just filed a patent for a hand tool for the electrical trade and have been tossing around the idea of trying to manufacturer this tool in plastic. This tool is struck by a hammer with a mild blow, most of the force is absorbed by what the tool rests on and does. I would equate the force used as the same as used to start a sheetrock nailin sheetrock,(I hope that helps)
Tips on what kind of plastic to use in this situation would be of great service to me.
Before I contact manufactures I would like to sound at least a little knowledgeable in this field.
Your help would be greatly appreciated.
Pete Tschudy
RE: What Type of plastic to use
Hi
I would suggest you use polycarbonate
Chinmay Kanuga
ckanuga@usa.net
Plastics Engineering
University of Massachusetts
Hi Boltazar,
I would recommend either Valox or Cycaloy, trademarks of GE Plastics These are ABS and PC/ABS blends essentially. You can/should visit www.geplastics.com and see what balance of properties are available to best suit your needs.
GEPlastics is also extremely helpful if you have any quesitons on their products, I've email corresponded with their technical people on a few occasions where I had to find just the right obscure material for an obscure project!
Hope this is somewhat helpful
Best Regards,
Paul R
Plastics that are "tough" (have relatively high strain energy capacity) include nylon (ABS), delrin and those previously recommended.  Impact resistance and fatigue strength will allow you to "size" the plastic for proper effect.  "Soft-blow" hammers (steel coated with plastic and hollow with shot balls) have been used for years.  Plastic hammers (solid rubber) have also been used by mechanics for years - they have a "bounce" to them however and may not behave as you intend.  The bulk modulus and modulus of elasticity (non-linear for plastics) will affect this "bounce" behavior.
