Hightlight of non-associative dimensions (NX2) ?
Is there a way to hightlight the dimensions that have lost their associativity while in monochrome background (exept the fact that its not moving anymore if you try to relocate them - which is not always visible) ?
Thx
Thx
RE: Hightlight of non-associative dimensions (NX2) ?
Jason
I haven't checked this out on monochrome but... I think a couple of things that come to mind may help. Under <Preferences> <Drafting>, change the font to something different (phantom?). This is the color/font settings for the 'system color and font' that would normally identify an unassociated dimension, so if you play with this it may help. Additionally, you also have the <information> <other> <object specific> menu options to play with that may help identify a problem. Finally, is there a reason you can't toggle the monochrome setting under <Preferences> <visualization> <color settings>?
Just some ideas....
SS
