External geometry,
External geometry,
I would like to know: How can I create a part with external features? I would create a sketch in a part and I would like to use this sketch in another part trough an assembly. How can I do that?
(I would like to know: is it possible to do something similar like the publish or copy geometry command in PROE? And How?) Please write me step by step!
Best regards,
Irwin
Best regards,
Irwin
RE: External geometry,
RMB\Edit part -then you can pick other edges\faces etc... to make In-context Geometry.
Beware of what you are doing because can get out of control quickly.
Check out h
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
