Evaluation of elements in a organic coating/paint
Dear all
I need to evaluate, both quantitative and qualitative, the elements and molecular constituiton of a coating/ paint applied by spray. This coating is used in situations of low friction needs.
I'm going to do some qualititive analysis in XRD and SEM/ EDX. XRD should give me the results very easily but they are only qualitative. SEM/ EDX for elements with atomic number lower than 12 is not very correct and also i think i have present in this coating several organic compounds, such as Graphite, Teflon and others, that EDX cannot establish the difference between molecules (Carbon is present in all the compounds i think exist in the coating).
My question is:
What should be a accurate and available way of determening what's present in this coating?
Best regards
Paulo Vilaça
My question is:
Best regards
Paulo Vilaça
RE: Evaluation of elements in a organic coating/paint
Inductively Coupled Plasma spectrometry (ICP) can evaluate the chemical composition of almost anything, although it can't differentiate molecules.
Gas Chromatography/Mass Spectrometry (GC/MS) can provide results for molecules.
Cory
In my college years i've worked sometimes with FTIR (i've forfot how!!!) but it gives me a qualitative analysis of what´s present in a determined sample. For quantitative analysis is ICP (which i ddin't knew before) suitable? what technique you think would be helpfull for a quantitative analysis?
Thank you in advance and best regards
Cory
