ITERATIONS in calling programs from EXCEL
who knows how to use an excel macro to launch an analysis program?
i have to perform a parametric structural analysis, and i intend to create an excel sheet whith all the parameters data, with a macro that activates the structural program at each iteration and also copies the output at each step
thanks
RE: ITERATIONS in calling programs from EXCEL
It should not be a problem. We would just need some more information on how the analysis program is run. Is it a standalone program that accepts parameters or is it incorporated in your workbook. Needless to say, you'll have to give more detail before we can start working on a solution.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
Use function Shell("C:\programfiles\myapplication.exe") to run external program within Excel. If your program creates text output file you will have to read it line by line like:
Dim TextLine
Open "TESTFILE" For Input As #1    ' Open file.
Do While Not EOF(1)    ' Loop until end of file.
    Line Input #1, TextLine    ' Read line into variable.
'analyze Textline using string functions to find the data you need
    Loop
Close #1    ' Close file.
yakov
the program i use is SAP2000
I don't now much how SAP2000 works. In GTSTRUDL there's a way to run program in a batch mode since it's text input file driven program. The command looks like:
Shell("C:\program files\gtstrudl\gtstrudl.exe inputfile.dat -l outputfile.out")
You need to contact SAP2000 support for syntax and for the key to access the database. Good luck!
Hi, anyone knows how to open a zip file(a.xls) from excel macro? Please advice. Thank you.
