Bus Bar Angle Through CT
Will a window CT operate at rated accuracy when the current-carrying bus bar passes thru the window at a 45 degree angle?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Bus Bar Angle Through CT
I'm not sure I understand/agree with your statement on breaking the primary current into "vectors". Do you mean mechanical vectors or something along that line or are you referring to the magnetic field lines? Either way, the line of thinking that the magnetic field lines must be perpendicular or parallel to the plane of the CT (and I'm not sure how you define plane) is flawed.
The CT with angled bus will probably read very close to the ideal current.
