Cable Insulation Voltage
I'd like to select cable for AC230V created from single phase transformer as cable with insulation grade 150/250V. My selection is acceptable ?
RE: Cable Insulation Voltage
You can use cable rated at 250V not the 150V.  Or am I not understanding your question?
The standard rating for LV power cable is 600 V.
Hi shkim2000 , if your system is 230V , according to all standards your isolation minimum value is 600V but it is usually requested to be at 1000V isolation . Be sure that you are not in an area wher regulations will force you to have higher isolations as in some European countries the requests are higher .
Good luck !
Avishai
A.Rash BScEE & PE
a_rash@bigfoot.com
