Welded Extended Web Beam Connection
I have been faced with this problem many times, designers specifying beam to beam connections for equal sized beams with both flanges of the incoming beam coped, with only the flat portion of the web extending to meet the web of the continuous beam, and connected with a double fillet.
I see two problems, one, concentrated stress at the top and bottom of the framing beam web where it connects to the web of the continuous beam, and two, a shear buckling weakness in the extended web tab.
__________ __________
|____ ____| |__________
........| |______|
........| |______
____| |____ |__________
|__________| |__________
I cannot find any reference for calculating the buckling capacity of the shear tab, where two edges are supported and two are free.
Any suggestions?
........| |______|
........| |______
Any suggestions?
RE: Welded Extended Web Beam Connection
tg
